1. Home
  2. Help Centre
  3. Polyboard tutorials
  4. Carcass
Basic shapes
To design a cabinet in Polyboard we always start with a basic shape. This is the shape of the plan...
Free shapes
How to draw a custom cabinet plan which is not necessarily rectangular. This feature allows you to design complex shaped...
Adding plinths
Polyboard has a specific plinth feature. There are 2 ways to add a plinth, depending on whether the sides are...
Upper strips
If you are designing a fitted unit right up to the ceiling, it is sometimes advisable to leave gap and...
Face frames
How to set up face framed furniture quickly and easily using external zones (lateral/side zones, plinths and upper strips) plus...
Add a side slope
How to slope the side of your cabinet to a specific angle. In addition, use of the Free Shape Edit...
How to create a sloping top
This video shows you a quick way to create a sloping top for your Polyboard model, either from left to...
Multi-slope tops
A look at Polyboard’s multi slope top feature which gives you fine control over the shape of the top of...
Polyboard’s unboxing feature
How to very quickly fit your model around structural elements like pipework and columns. All changes are automatically applied to...
Advanced plinths
How to set up plinths, toe kicks, and kick frames in Polyboard.
Kick frames
How to assemble kick frames or kick boards that you can use to sit cabinets on top of in Project...
