CNC integration
PolyBoard works with all types of CNC software and machines. These guides explain the process, the set up, the post processors that are available, and we’ve also included sample output for testing. Please contact us for further information if required.
CNC machine integration with PolyBoard
If you’ve got a CNC machine, or you’re planning to buy one, your choice of design software will be based...
CAM software integration with PolyBoard to run your CNC
Our PolyBoard CNC design software directly outputs native CAM software files for a range of popular brands of CNC including...
DXF post processor parameters (PolyBoard)
PolyBoard has an extensive range of post processors that can be flexibly configured to work with practically any CNC machine....
Enhancing CNC workflow with multiple post processors
PolyBoard’s multiple post processor feature empowers users with expanded capabilities for managing data sent to CNC machines. It offers a...
PolyBoard integration with OptiNest
OptiNest is a stand alone nesting optimisation solution. However, it combines very well with PolyBoard which we’ll show you in...
Homag / Weeke CNC integration with PolyBoard
Design in PolyBoard then output woodWOP’s native .mpr files with all hardware and assembly details automatically included. The fastest and...
Biesse CNC integration with PolyBoard
Design in PolyBoard then generate bSolid or BiesseWorks .cid/.cix files with all hardware and other machining details already in place....
SCM / Morbidelli CNC integration with PolyBoard
Design in PolyBoard, output native .xxl files for Xilog Plus (or .xcs for Maestro) complete with full hardware and assembly...
Felder / Vitap / Brema CNC integration with PolyBoard
Wood Designer is an official Felder productivity partner Output your completed PolyBoard project in TpaCAD’s native .tcn files, complete with...
Direkt NC-HOPS integration with PolyBoard and StairDesigner
Our software combines with virtually any CAM package and CNC machine type. That covers NC-HOPS as well, a powerful CAM...
Alphacam integration with PolyBoard and StairDesigner
Our software integrates with pretty much all CAM software and CNCs. That includes Alphacam, one of the best known and...
VCarve integration with PolyBoard and StairDesigner
Here we focus on VCarve, but the same integration applies to Aspire. We have partnered with Vectric so you can...
How to set up PolyBoard and OptiNest for import to Maestro
For SCM point to point CNC machines equipped with the CAM software Maestro, PolyBoard can export XXL files that can...
PolyBoard and OptiNest nested manufacturing with doubled sided machining and edge drilling
In nested manufacturing a complete sheet of material is placed on a flat bed CNC and parts are machined and...
PolyBoard to OptiCut post processor label synchronisation
How to set up an export of a PolyBoard project to OptiCut and print the correct labels with CNC file names.
Point to point versus nesting CNC machines
Which is going to be best for your workshop, and recommended software configurations for each. PolyBoard acts as the design...
