- Home
- Knowledge Base
- Polyboard tutorials
- Hardware
Hardware
Polyboard allows you to add virtually any hardware or fitting to your projects you want. All the machining for CNC manufacture is included. Use our ready made Quick Design hardware library, or add your own configurations.
Either way, automatically apply your favoured hardware using our Quick Design methods.
Add hardware using the fitting links option
In this video we will show you how to add hardware to your models using Polyboard’s links feature, and within...
Using Quick Design hardware fittings
How to use Quick Design to change all the hardware in a project with one click of your mouse. For...
Using Quick Design placement rules
This video explains the Quick Design rules for hardware placement. Please note, these hardware rules are now organised into folders.
Using Quick Design fitting links
Setting up Fitting Links sub-methods from scratch can be a long and error prone process. This video shows how to...
Handles, specialist fittings and other 3D accessories
This guide covers how to create and add 3D images of hardware and other accessories to enhance the 3D view...
Using the Quick Design hardware template
The latest version of the Quick Design libraries contains a special hardware set up template to make it far easier...
Hardware positioning
How to use the fittings function to move hardware positions independently of the placement rules.
Blum hardware set up
An overview of the Blum hardware featured in Polyboard’s Quick Design libraries, including drawer sliders, hinges and various miscellaneous items....
