Output (non CNC)
The different options for processing the output of your manufacturing files, and how to set them up.
PolyBoard’s workshop document: cut list, plans and cost report
In this video we’ll show you how to print out and modify the cut list, plans and costings for your...
PolyBoard to OptiCut integration
OptiCut works as a stand alone cutting optimisation solution. It also has a very good integration with PolyBoard which we’ll...
The measuring tool and dimensioned plans
Accurate dimensioned drawings are critical for an efficient production and assembly process. PolyBoard is able to output a range of...
Printing part by part labels
Optimisation software like OptiCut and OptiNest will produce the labels for your parts. If you are not using optimisation software...
Quote module
PolyBoard includes a highly customisable quote function. This feature is accessed via the File menu > Quote. Print quote and...
3D renders and PolyBoard models
Examples of the 3D rendering possibilities within PolyBoard. Many of these models are available within PolyBoard’s Quick Design libraries for...
Photorealistic renders from PolyBoard and StairDesigner
This tutorial will explain the process for converting your PolyBoard and StairDesigner projects into photorealistic images using our CabinetRender and...
3D DXF and 3DS output formats
As well as producing manufacturing output, it’s possible to export 3D designs from PolyBoard to a rendering package or to...
Catalogue mode overview
Catalogue mode is used for 3 reasons: To create the manufacturing documents where you don’t need to draw a new...
Cutting list export
To view the cutting list on screen, go to Cutting list menu > Cutting list: CSV/TXT export In addition to...
Numbered parts
PolyBoard includes a simple number reference for all parts which is included in the manufacturing output to make the production...
ERP export
As you design, PolyBoard’s internal cost and materials report is dynamically updated. It’s possible to set a material cost for...
Hardware list export
It’s possible to output a list of all the hardware used in your PolyBoard design as a delimited .txt file....
