- Home
- Knowledge Base
- PolyBoard tutorials
- Project mode
Project mode
In Cabinet Mode you design a single piece of furniture. In Project Mode you create the environment (normally the room layout) of your project. You are then able to quickly position, move and modify individuals units within it.
Project Mode is great for 3D presentations and assembly plans, and to check your project is workable in situ. It also allows you to build more complex units in smaller parts, so they are easier to design and manufacture.
Note: please watch the Quick Design Toolbar videos on the Getting Started page first. These cover many of the basic commands in Project Mode.
Drawing a room with coordinates
How to use the surface drawing editor to draw a room to precise dimensions. Once you get the room dimensions...
Adding openings with coordinates
How to use the wall edit tool to create openings for windows and doors.
Adding images to your project
You can apply any image file to any surface in Polyboard. This makes it possible to show doors and windows...
Adding cabinets to your project
Drop new cabinets into a room layout, measure and resize to fit the space you’re working with exactly. Note, Polyboard...
Adding a worktop and plinths to your project
How to add worktops and plinths across multiple cabinets in a project. Note, Polyboard now includes a specific filler/plinth feature,...
Changing your design using the Quick Design libraries
How to modify the Quick Design Libraries to change materials, and to add edging and hardware.
Fillers
Fillers are used to bridge the gap between walls and fitted furniture. Often, it’s a good idea to make your...
Plinths
As well as adding a plinth to a single cabinet in Cabinet Mode, you can add plinths below multiple cabinets...
Worktops
How to add a worktop or countertop across multiple cabinets in Project Mode. Editing options include the ability to adjust...
Cover panels
In Project Mode you have the ability to add cover panels in front, behind or to the side of your...
Move and rotate models
It’s easy to use the clipping function to position your cabinets in a project. However, sometimes you need finer control....
Snapping inside cabinets with a dummy model
In Project Mode, you can easily snap models to one another or snap a model to a wall. But you...
DXF import of furniture, walls and floors
How to use the DXF import functions of Polyboard to design a curved reception desk fitting a curved wall.
