- Home
- Knowledge Base
- StairDesigner tutorials
- Getting started
Getting started
A look at the key features within StairDesigner to help you set up your first stair project. These tutorials are also available on the download page.
Create a new stair
In this video we will learn how to select a new stair project from the list of models, set up...
General stair parameters and optimisation
How to display and modify the general parameters of your stair, including adjusting the number of steps to optimise riser...
Headroom control feature
StairDesigner includes a headroom control feature that allows you to confirm the safe passage up to the next floor level....
Modifying winders
Winders are tapered steps, so their edges are not parallel to each other. In most European countries, these winders are...
Multi flight stair mode: straight flights
In this video we will use the multi flight option to create a series of straight flights. This offers a...
Multi flight stair mode: circular flights
How to use the Multi Flight Stair Mode to create a curved stair of one or more curved elements. Each...
Adding landings
How to add a landing in StairDesigner. You can either open up one of the pre-configured stair models that includes...
