1. Home
  2. Knowledge Base
  3. PolyBoard tutorials
  4. Design tips
  5. Corner cabinet with fixed panel and door
How to set up a corner cabinet with a fixed panel and door aligned, with the door set in flush with the panel.
This query comes up quite often, because you need a fixed panel for the door to be hinged on to, and to cover the next unit going in the other direction.
The free shape method used allows you to manage the dimensions of the panel.
