1. Home
  2. Knowledge Base
  3. Polyboard tutorials
  4. Carcass
  5. Create a baton (using the back external zone)
How to create a volume behind your cabinet and in this case add a baton, which will of course be included in the cut list with the correct dimensions.
And if you resize your cabinet, the baton will automatically resize too.
You could just as easily use this method to add multiple rails where extra rigidity is required.
