Manufacturing output
Essentials: previousnext
PolyBoard has been created as a design to manufacturing solution. It offers instant access to all manufacturing output which is dynamically updated as you design.
polyboard manufacturing output
We have detailed advice on the output options in the Help Centre here:
Manufacturing output (non CNC)
CNC integration
Sample output
Examples of the available output can be found here:
PolyBoard download page
Manufacturing output options
Here’s a simple overview of what’s available:
Cutting lists
Sorted by cabinet or material, also available as a configurable csv file.
Part by part plans
Plans of every part available for printing including machining coordinates and cut angles.
Dimensioned drawings
Fully dimensioned isometric, plan and cut through views of individual cabinets and complete room layouts.
Labels
Highly customisable including QR code and barcode options.
3D renders
  • Textured and wireframe views
  • Add shadows and other lighting effects
  • Rotate to any angle
  • Zoom in and out
CabinetRender photorealistic images
Use our complementary CabinetRender AI tool to create beautiful photorealistic renders of your PolyBoard projects. Adjust lighting, textures and hardware in seconds with simple prompts.
Cost and material usage report
Including panel, bar and edging materials used, hardware and machining costs.
3D DXF and 3DS output
For import to CAD software.
CNC output
  • Files of every part in industry-standard 2D DXF format, compatible with all CNC software
  • Additional native file format CNC output for a range of popular CNC brands
  • Multi post-processor feature to split CNC output across different machines
Catalogue mode
For bulk manufacture from your model library.
Seamless integration with OptiCut and OptiNest
For cutting and nesting optimisation respectively.
ERP output
Highly customisable output for your ERP solution.
Hardware list
Details of all hardware used in your project, exported as a .txt file.
