Multi-slope tops
A look at Polyboard’s multi slope top feature which gives you fine control over the shape of the top of your models.
Working with coordinates or simply by adding and dragging points with the drawing tool you can create a slope from left to right, from front to back, combine the two slopes and more.
All cut angles and plans are updated to include this complex geometry.
