OptiCut works as a stand alone cutting optimisation solution. It also has a very good integration with PolyBoard which we’ll show you in this video.
Design your furniture project in PolyBoard, output the parts to OptiCut to produce optimised cutting maps for your saw.
Now with full grain matching. Set the grain parameter in PolyBoard for your desired parts, and OptiCut will group them together in the cutting map so the grain flows perfectly across them.
More information:
