Plinths
As well as adding a plinth to a single cabinet in Cabinet Mode, you can add plinths below multiple cabinets in Project Mode.
The plinth can be moved, recessed and like any other panel you can change the material, add edging and tooling if required. It will also be included in your manufacturing output.
