1. Home
  2. Knowledge Base
  3. PolyBoard tutorials
  4. Shelves and uprights
  5. Upright cutting through shelf with face frame added
This videos covers two concepts.
If you need to cut one panel through another, a good way to do it is with the groove feature. Here an upright is extended through a shelf.
This model is complicated by having a face frame on the vertical panel or upright. To manage this add a separate space in front of the upright using a false double back which is a nil panel. Then add another upright for the face frame into this space.
