Polyboard Pro PP
Outputs post processors files for MRP (woodWOP, HOMAG machines), CID and CIX (BiesseWorks and bSolid for Biesse machines), XXL (Xilog Plus and Xilog Mastro for SCM / Morbidelli machines), TCN (TpaCAD for Felder, Vitap, Brema), HOP (NC-HOPS for Holz-her etc) and DXF files for any standard CNC or CAD/CAM software.
StairDesigner Pro PP
Outputs post processors files for MRP (woodWOP, HOMAG machines), CID and CIX (BiesseWorks and bSolid for Biesse machines) and TCN (TpaCAD for Felder, Vitap, Brema) and DXF files for any standard CNC or CAD/CAM software.
StairDesigner Pro
Outputs DXF files and so will work with virtually any CAM software and CNC machine.
OptiNest
OptiCut
Comes with a large range of CNC saw post processors.
More information
Click below for full CNC integration details, plus sample manufacturing file downloads to test with your machine:
Polyboard / CNC Integration
StairDesigner / CNC Integration
OptiCut / CNC saw integration
OptiNest / CNC integration
You can load the machine code into your machine interface and see quickly if your machine is compatible with the code. Please note that our post processors will need to be set up with the right tool paths and options to correctly cut your parts.
This element is not necessarily set up correctly in the example code. The code is just to see if your machine interface will read the output.
Please contact us for more details
