- Home
- Help Centre
- StairDesigner tutorials
- Essentials
- Recommended workflow and next steps
Essentials: previous
- Use StairDesigner to its full potential
- StairDesigner grows with your business
- Next steps and further resources
A quick reminder that to get the most out of the software please check out all the resources in the Help Centre, there are some really powerful features you might not know exist. Plus lots of advice on fast ways to design your projects.
These options will help too:
Models library
- Develop a model library of commonly used designs; save these as new projects, then edit the dimensions and replace selected components as required
- This is one of the fastest ways to work
Manufacturing methods
- Set up your own construction preferences as Manufacturing methods
- This ensures the design to manufacturing process is easy, fast and accurate
- If you need to make a change to your preferences just tweak the appropriate sub-method and you’re done
Explore the full range of design capabilities
- Whether you start with a StairDesigner model or in multi-flight mode, the ability to add, remove and edit flights, landings, apply curved parts and lots more opens up a huge range of design possibilities
- If you’re not sure how to get started with your specific design concept and cannot find what you need in the Help Centre, just ask on the forum
Non CNC production
StairDesigner Pro
A great option to design fast and accurately, with instant access to part by part plans, 1:1 templates and great 3D renders for your customers.
CNC production
StairDesigner Pro PP
If your business is ready to make the move to CNC production, upgrade to StairDesigner Pro PP for integration with virtually any CNC software and machine setup.
Need help with the integration? We offer 1-2-1 support with this.
StairDesigner Pro PP and point to point 4/5 axis CNC
Perfect for specialist stair manufacture, with the ability to machine all your parts, from complex stringboards and handrails to newels, steps and risers.
StairDesigner Pro PP, OptiNest and a nesting CNC
A great way to save material cutting your steps and risers (especially winders), this method also supports multiple stringer options, even when larger than the working area.
Our software OptiNest provides the nesting function including advanced labelling and off-cut/stock management although your CNC software may offer this functionality too.
Further information on your CNC options
Please contact us if you would like to discuss your plans.
We’ve supported a huge range of customers so are well placed to advise on the best CNC setup to suit your workshop and needs.
Help Centre
Go to our Help Centre for more resources.
Here is a list of links to all StairDesigner Help Centre categories:
- Essentials guide (reading now)
- Extended tutorials (including advanced shape editing features)
- Output (non CNC)
- CNC integration
Training
We offer 1-2-1 online training in StairDesigner: details of training packs.
Support forum and screen share sessions
Premium Support (included with your first software order) gives you access to technical advice on the forum and via screen share sessions.
Get started with StairDesigner today
- Register here to download StairDesigner
- All design features are available with the free version of StairDesigner
- Any project you create with this version will be available in the fully activated version of the software
Want to see StairDesigner in action?
Schedule a session with a member of our technical team, and cover any queries you have.
How to contact us
Click here to contact us by phone or message.
Thank you for reading, we hope you enjoy using StairDesigner!
