Knape & Vogt from the US have partnered with Samet with its global reach to offer a range of premium drawer, door and cabinetry fittings.
Their innovative but functional hardware is now integrated with PolyBoard cabinet design software for 100% accurate application and instant access to the machining and part manufacturing output, whether you’re working with or without a CNC setup.
Let’s take a look at some of the highlights:
Drawer box systems and runners
Features include push to open and soft close damping, a lot of variability in height, length and material options, storage insert accessories and tool free assembly of drawer fronts.
Knape & Vogt / Samet fittings
Here’s a summary of each system:
  • ALPHABOX (pictured): full extension, minimalist with slim sides in white/grey/anthracite, glass and side rail options, loads up to 40kg / 88lbs
  • FLOWBOX: full extension, 12.8mm extra thin sides, colours white/grey/inox/mocha/anthracite, 4 height options, glass side option, 40kg / 88lbs loads
  • SAM BOX: single extension, steel appearance in white/metallic grey/cream, carrying capacity 25kg / 55 lbs
  • SMART BOX: full extension, more flexible design options in grey/white, single and double gallery rails, compatible with Invaria cutlery solution, carrying capacity of 40 or 65kg / 88 or 143lbs
  • SO CLASS: soft-close ball-bearing slides, configurable for SIDEBOX and ROLLBOX setups
Insert options include sink solutions, the Invaria cutlery solution and super flexible Artflow magnetic organizers, shown below.
Artflow magnetic organizer inserts for Knape and Vogt / Samet
Lift systems
The Solo Mech hingeless lift system is designed for single doors, with a load capacity of 14kg / 30 lbs. Color options are white/grey/mocha/anthracite with additional cover customisations.
Solo Mech lift system
Especially important for lift systems, the door closes gently and silently. Can be opened fully or held at a series of intermediate positions.
Hinges
We have included the Master soft close hinge system (shown below) with 110° opening in nickel and black. It is fully adjustable in height, depth and to the side. Integrated track mechanism allows for tool free assembly and disassembly.
Samet Master hinge
Another option to choose from is the Star self close hinge with 95°/110°/165° opening in nickel. This is also fully adjustable.
CAMs
Samfix is a panel corner connector that locks in place with a screwdriver rotation. Dowel expansion makes for simple assembly and disassembly. Comes with a cover cap.
Samfix cam and dowel fitting
Fully integrated with PolyBoard cabinet software
All these fittings (plus a huge range of other construction preferences) are configured for use with our PolyBoard cabinet software.
Unlike most traditional CAD software, PolyBoard is a true design to manufacturing solution.
That means the cutting list, plans and CNC output are dynamically updated and immediately available as you edit your design.
Please contact us if you’d like a demonstration with a member of our technical team.
You can also download PolyBoard here.
