Video Transcription
This is a short video to show you how to set up doors that only have two styles and a central panel without any rails. This is how to do it quickly and easily.
Let’s open a new cabinet and give it a height to give it a decent shape and add some double doors. Now we can go in to one of the doors and edit its structure.
add doors to your cabinet
Go to the Assembly Method > Overpassing Uprights and then put in a central panel of say 19 mm beach.
assembly method overpassing uprights
19 mm beach material for panel
Now select the Upper Cross-Bar and select the Material as ‘Nil Bar’.
upper cross bar nil material
To get to the Lower Cross-Bar and eliminate it, select ‘Display Advanced Parameters’ and do the same thing, make the Material a ‘Nil Bar’.
display advanced parameters
lower cross bar as nil bar
And then we have the panel centred onto the thickness of the uprights.
panel centred on the uprights
To step it on to the backs, make sure the door is still selected and edit the structure again. Go into Central Panel > Alignment and change it from Centred to Back.
align with back
making cabinet doors
To do the same with the other door, make sure the first door is still selected (orange in colour), go into Properties > Door 1 > click Copy the Structure.
make cabinet doors
Now go into Door 2 (which should turn orange now) > Edit > Paste Structure. The structure of the first door is now copied across to the other.
paste structure to door 2
There we have it. Two doors with continuous styles and a single intermediate panel.
two door finished
You can view the complete Polyboard tutorial series here.
Thanks for watching.
