Renowned for innovative space optimization, Kesseböhmer continues to refine its kitchen storage solutions. The LeMans pull out larder is probably their most recognized contribution to the industry, maximising previously difficult to access and underused corner areas of a kitchen.
We have configured the LeMans alongside a large range of their most popular products for use with PolyBoard cabinet software. Instantly apply the precise machining details to part by part plans and CNC files.
Kesseböhmer fittings configured for use with PolyBoard
With Kesseböhmer, you benefit from:
  • Market leading products that use space as efficiently as possible
  • Engineering excellence and longevity, with a particular focus on ease of installation
  • Minimalist modern designs; for materials and finishes think chrome, anthracite, whites and neutral greys
Let’s take a look at some of the Kesseböhmer products now available for use with PolyBoard. If you don’t see what you need, please just ask, we are adding configurations all the time.
Corner units
LeMans corner unit
LeMans
Kesseböhmer’s flagship corner cabinet product, now copied the world over. Turn and swivel shelves in and out independently, great use of a hard to reach space. Excellent build quality manages heavy loads alongside the high stresses applied to the fittings.
Larder units
Convoy larder unit configured for use with PolyBoard
CONVOY
This wide full height larder comes with adjustable height floating shelves. Attach glass sided storage trays to a single tube frame behind the door. We’ve added the CONVOY Centro to our configurations, if you need additional variations please just ask.
DISPENSA larder unit
DISPENSA
Another imaginative space saver solution, this pull out larder comes with some great storage customizations and access from both sides.
Wall units
FREEfold lift system by Kesseböhmer
FREEfold
This lift system design accommodates cabinets just below the ceiling. Includes a multi-position stop feature for modern kitchens.
iMove by Kesseböhmer
iMove
A wall unit storage system that pulls out and down and is ideal for accessing and viewing cabinet contents. iMove still provides room for a standard shelf below the pull out component.
DUO by Kesseböhmer
DUO
A classic lift system, opening up to 110°, but with a twist. It includes the option to open downwards, with the front doubling as a shelf.
Base units
Kesseböhmer COMFORT
COMFORT
This base unit is a great mini larder option; access the entire cabinet contents with one pull. Examples of inserts include the ARENA range of plastic trays and also a metal basket alternative.
No. 15 by Kesseböhmer
No. 15
Perfect to max out the benefits of a narrow space in the kitchen, or add a little extra value to your designs. For something so compact, the No. 15 comes with stacks of options. Choose from 2 and 3 story shelving to towel racks to baking tray storage.
Design your kitchen fast and error free
Combine your favourite Kesseböhmer cabinet solutions with PolyBoard for seamless manufacturing. Our parametric software doesn’t work like traditional CAD which involves a lot of drawing and editing. Instead size your carcass and drop in doors, shelves, drawers and all other components, then select your Kesseböhmer manufacturing stylesheet.
The software does all the rest, all parts and all the machining details for the fittings are calculated 100% accurately. Swap drawers for doors, edit the dimensions, and the entire project updates instantly including all the hardware details.
Please get in touch with our technical team if you’d like to see PolyBoard in action.
