We’re delighted to be able to add OVVO as a hardware partner, a range of their most popular cabinet connection systems is now configured for use with PolyBoard.
OVVO’s focus is the delivery of tool-free fitting systems to make assembly incredibly easy. Their clients include bulk manufacturers of flat pack furniture so end user assembly has to be as simple as possible.
ovvo fittings
Their solutions are also widely used by custom cabinetry workshops, cutting transport costs and making on site assembly fast and error free.
We also love to highlight sustainability in design; their releasable connector range ensures single damaged parts can be removed and replaced.
Connectors now available for use with PolyBoard
Drilling and dowel connectors
For standard drilling on both sides of the joint.
ovvo drilling and dowel connectors
From left to right: OD830, DH1 + RN12, DH1 + RD12
End drilling connectors
These combine standard drilling for one panel, with the milling profile on the other.
ovvo end drilling connectors
PD20
Milling connectors
Milling housing profile on both panels.
Permanent connectors:
ovvo milling connectors
V-1230P (left) and 1240P (right)
Releasable connectors:
ovvo releasable connectors
V-1230R (left) and 1240R (right)
Face boring connectors
Perfect for single face machining.
ovvo face boring connectors
PN12 (left) and RN12 (right)
Manufacturing with PolyBoard and OVVO
Design in PolyBoard cabinet software and set OVVO as your preferred panel fittings. The connectors will be dynamically applied as you build your projects. Resize the cabinet box and they will be removed or added automatically too.
A range of connectors has been added to this simple cabinet in PolyBoard, click to enlarge.
OVVO’s connectors are designed for CNC manufacturing, please go to the OVVO website for router cutter specifications to make the required profile. Also click here for a list of international OVVO distributors.
PolyBoard will transfer all the part and machining details to your CNC machine and automates toolpath application for an even faster workflow.
As an alternative to CNC production, OVVO has linked up with a number of suppliers including Virutex to develop the AB181-VD connector milling machine specifically for its fittings range.
How to access your new OVVO hardware?
We have included a selection of OVVO connectors in PolyBoard’s Quick Design libraries. The full selection is available as a Hardware Pack to all Premium Support subscribers from their account page.
Please note, a free Premium Support subscription is included with your initial PolyBoard order. If you’re thinking of using PolyBoard in your workshop, please contact us to arrange a demo with a member of our technical team.
