The carpentry and woodworking industry stands at a crossroads of tradition and innovation. As awareness of climate change and environmental responsibility grows, cabinet makers and carpenters play a critical role in building a more sustainable future.
Aerial view of deforestation
Deforestation on a global scale
As well as a look at some of the best eco-friendly materials on the market, we’ll consider responsible sourcing, waste management and greener workflows. These practices not only support environmental health but also strengthen trust with increasingly eco-conscious customers.
Climate change and the furniture manufacturing industry
Carpentry has a strong connection and influence over the health of the environment, with direct relationships with forests, which acts as carbon sinks. The unsustainable sourcing and manufacturing will significantly contribute towards greenhouse gas emissions and deforestation.
FSC and PEFC logos
FSC and PEFC certifications
If a business wisely sources materials, reduces their waste, and takes on efficient production practices, the industry can help to limit climate impacts. Across the world customers are much more likely to expect high levels of sustainability in what they buy, and use of certification schemes such as FSC and PEFC. Adopting these schemes are not just good for the environment, but also build trust amongst an increasingly eco-conscious society.
Managing waste in carpentry
Sustainable material management is a key component of responsible carpentry practices. In a summary of how workshops can become more efficient and environmentally friendly through smart wood waste strategies:
  • Design software such as PolyBoard; reduce mistakes dramatically and benefit from a large range of hardware that allows disassembly and replacement of parts; this increases the lifespan of your cabinetry
  • Cutting optimization: using software to map out cutting patterns and minimize scrap material, for examples using OptiNest for nesting and OptiCut for cutting optimization
  • Stock management: utilizing off-cut/stock management system such as OptiNest, OptiCut or an ERP to prevent over-ordering and to streamline administrative operations
An optimized material sheet in OptiCut
Optimizing cutting patterns with OptiCut, reusable off-cuts are easily identified and automatically returned to stock
Support these actions with your own tree-planting schemes or using recycled finishes; these can make a big difference over time. There are a growing number of planting schemes that suit all business sizes, consider as we do making a contribution or planting a tree with every order you receive.
Engineered sustainable materials for carpentry
There are many innovative engineered materials that are both sustainable and high-performing. New products now allow carpenters to reduce their environmental impact without having to sacrifice construction quality.
NRG Greenboard
NRG Greenboard is an Australian product designed for external cladding. It’s an insulated wall panel system that combines exterior cladding with a high-density expanded polystyrene insulation. The material integration allows designers to achieve an energy efficiency building that meets modern thermal performance standards.
Here are some of the benefits of NRG Greenboard:
  • Offers good energy efficiency ratings for appropriate environments
  • Good weather resistance with a seam-free rendered finish when coated
  • Offers integration with timber, steel, concrete, and masonry frames, allowing for design flexibility with diverse architectural applications
  • Offers good fire resistance properties and pest deterrence
Hybrid decking materials
Hybrid decking is typically a combination of recycled wood fibres and plastics that create a durable and low maintenance outdoor material.
A deck made from hybrid decking materials
A hybrid decking solution from ecodek
These materials assist in reducing landfill and conserving natural timber resources. Hybrid decking materials boast:
  • High resistance to rot
  • High resistance to moisture
  • High level of insect resistance
  • Outperform untreated solid timber in longevity
Laminated veneer lumber (LVL)
Laminated veneer lumber (LVL) in an engineered timber material made by layering thin veneers and bonding them with an adhesive. LVL’s offer dimensional stability, exceptional strength, and uniformity. They often surpass solid timbers in their load-bearing applications.
LVL timber
LVL beams and furniture showcasing the laminated veneer layers, from Stora Enso
The modern day production of LVL’s increasingly uses reclaimed or sustainably sourced timbers, providing efficient use of resources. LVL performance makes it ideal for beams, headers, and other structural components that support sustainable practices.
The value of reusing wood
Reusing timber is one of the most cost-effective and impactful sustainability practices. Salvaging timber from old projects or off-cuts extends its lifespan far beyond single use.
Recycled timber used in construction
Recycled timber used for ceiling beams
Reclaimed timber is increasingly sought after as a design element, valued for its character and environmental benefits. By reusing wood, carpenters help reduce logging, landfill, and the energy and other climate costs associated with producing new materials.
The MDF challenge
MDF is manufactured from wood, a renewable resource, but its rising popularity puts added pressure on forest conservation, especially in sensitive areas like the Amazon. Global production has surged from around 23.6 million m³ in 2001 to nearly 111 million m³ in 2021, reflecting strong market growth.
This rapid increase poses serious challenges for MDF recycling; more waste needs to be dealt with, especially as the material typically lasts only about 14 years.
A large pile of MDF fibres
Shredded MDF fibres
On top of end-of-life waste, around a quarter of all MDF made each year is lost before it’s ever used – through manufacturing off-cuts, machining mistakes, transport damage, and storage losses. As demand keeps climbing, both production and waste volumes are rising, highlighting the need for more sustainable handling and recycling of MDF products.
There are practical methods currently in use for recycling MDF, though they are limited and not as widespread as recycling other wood products:
  • Mechanical recycling: the process of shredding MDF panels into small fibres for reuse in other manufactured boards
  • Energy recovery: the process of burning MDF for fuelling cement kilns, biomass plants, or waste-to-energy facilities
  • Chemical recycling: the process of breaking down MDF chemically to recover the fibres, resins, and other compounds; this process is not industrially common and is still mostly in research stages
Looking ahead: next generation materials
As awareness of environmental issues is increasing, many researchers have tried to find environmentally sensitive solutions to reusing timbers, especially treated wood that can be toxic to people.
An example of this was seen in a 2023 study in the Construction and Building Materials journal, by authors Firesenay Zerabruk Gigar et al.. This found that untreated woodchips showcased strong positive results when compressed into geopolymer cement bonded wood composites (WGC).
Strength testing of WGC
Compression strength material testing for geopolymer cement bonded wood composites
The study demonstrates potential for both load-bearing and non-load-bearing construction applications, especially at lower wood contents. Beyond mechanical performance, the process provides a sustainable waste-management solution by repurposing toxic CCA-treated timber and reducing the need for virgin raw materials. It also supports resource conservation, diverts hazardous wood from landfill, and offers a lower-carbon alternative to conventional cement-based products.
If testing results continue to be positively focused, and production of the material is achievable, this may become a more common construction material in the industry. If testing is focused toward materials such as MDF and plywoods, and proper pre-treatment is undertaken, this could transform material waste in the carpentry industry.
Health, safety, and cost considerations
Sustainability in carpentry is about more than the environment; it also involves protecting people and ensuring financial viability.
  • Worker health: low-VOC finishes, water-based adhesives, and proper dust extraction improve indoor air quality and reduce long-term health risks; choosing low-emission engineered materials (E0/E1 certified) further safeguards workers and end users
  • Safety with engineered products: MDF and particleboard often contain formaldehyde-based resins; opting for safer alternatives, including formaldehyde-free MDF, limits harmful exposure
  • Financial sustainability: while some eco-friendly products cost more upfront, they typically lower expenses over time through greater durability, energy savings, reduced waste, and stronger customer trust
low VOC varnish
Low VOC varnish, options include water-based polyurethane or plant-based options like soy, carnauba wax and beeswax
By balancing people, planet, and profit, workshops can achieve sustainability that is both responsible and practical.
Step by step progress
Building a sustainable carpentry industry does not require radical overnight changes. Progress comes from thoughtful, informed decisions about sourcing, design, and manufacturing.
With support from certification bodies, smart software, recycling initiatives, and innovative new materials, carpentry has a unique opportunity to align craftsmanship with environmental responsibility…ensuring tradition evolves into a greener future.
References
  • Firesenay Zerabruk Gigar, Amar Khennane, Jong‐Leng Liow, Biruk Hailu Tekle, & Katoozi, E. (2023). Recycling timber waste into geopolymer cement bonded wood composites. Construction and Building Materials, 400, 132793–132793. https://doi.org/10.1016/j.conbuildmat.2023.132793
  • Zimmer, A. and Angie Lunelli Bachmann, S. (2023). Challenges for recycling medium-density fiberboard (MDF). Results in Engineering, [online] 19, p.101277. https://doi.org/10.1016/j.rineng.2023.101277
