Professional 3D bedroom design software
Specialist 3D bedroom design software for your business.
Whether you design custom projects every time or work with standard units, PolyBoard gives you the power and flexibility to get from concept to assembly fast and error free.
bedroom software
Looking for a bedroom design tool you can count on?
PolyBoard is a complete production solution.
Flexibility to create all bedroom furniture including beds, desks, wardrobes, chests of drawers, fitted shelves, storage units, steps & ladders, under bed storage and so much more.
Bedroom furniture design software that is much faster than drawing in CAD
...with your cut list, plans and CNC files all immediately available
Quick answers to design challenges
Apply a sloping top or side if the room’s ceiling or walls demand it, generate a cut out around pipework or another obstacle, adjust your units to fit against walls with unusual angles. Your design recalculates all the manufacturing documents instantaneously.
Instant 3D bedroom designer visuals
The perfect way to present to your customer. The fast design process means you can very quickly produce a rendered 3D image of your project before closing the deal. For the same reason, you can even edit the design in real time with your client if you want to.
Cost management
With any change you make, the costs of the project are updated. These are based on material use and price, and the hardware you’ve chosen. Quickly produce accurate quotes you can rely on.
Manufacturing power on tap
Apply your own manufacturing standards with the click of a mouse…the combination of materials, how you like your edging set up, carcass construction, hardware type and position and so on.
Bedroom Furniture Design Software
"Anyone not using this software really should be."
Lippy Brenig, Philip Morrison Interiors
More ways our bedroom design software will make your life easier
wardrobe under eaves in small bedroom
Under bed storage design software
Bed Design Software
Drop all your units into a dimensioned 3D project plan, reposition, test the fit, and easily resize where necessary…all parts of any resized unit are updated immediately. NO re-drawing in CAD required!
Plinth, top rail, worktop, filler management. Per unit, or across multiple units. All included in the manufacturing documents for easy production and assembly.
Complete drawer manufacturing solution with every element customisable, from hardware type and position to play, slack, façade design, depth, variable dimensioned multiple drawers etc.
Comprehensive hardware management covering all major brands like Häfele, Hettich and Blum, for hinges, drawer sliders, panel assemblies etc.
Specialist hardware including sliding doors, nesting hardware like Nest-fix/Rafix/Lamello, folding doors, hanging rails, drawer cut out handles etc.
Tooling inlays, veneers, panels with multiple materials, curved panels, bar material management.
Where next?
Let us know if you would like an online demo of our bedroom furniture design software, PolyBoard.
Register for free then click below to download our bedroom software which allows you to design your projects in full. Only the output is turned off but we have sample cut lists, plans and CNC files available to view and test on the download page.
