Stair testimonials
Sent in from users of our StairDesigner software and our StairFile and other services.
Please get in touch if you would like us to feature your work here or if you would like us to create an article about your experience.
Julien Lauvand
Stair manufacturer
"I'm writing to you almost a year since I began working with StairDesigner. The software has allowed me to expand into stair manufacture by removing all the complicated steps you often have to deal with in a smaller workshop. Calculations are also very easy. Here are some pictures of the first staircase I made with StairDesigner."
The StairDesigner software is fabulous. I had a trawl through the web and this is the best app available.
Professional woodworker
I have made my stair thanks to your software. It’s a quarter turn with winders, difficult to calculate because of a very small stairwell that’s only 1750mm long... it all worked out fine in the end thanks to your software and help.
Amateur stair builder
I would humbly give the following advice...use Wood Designer’s StairFile service, it will save you hours of calculations and possibly expensive errors.
StairFile user
Jérémie Lavigne
Professional stair builder
Jérémie has sent us a short video of his stair that highlights superbly his craftsmanship and how with a little help from StairDesigner and our StairFile service you can put together some amazing projects.
I've been making stairs for 20 years. StairDesigner is a beautiful tool, the 1:1 templates are extremely precise, save me a huge amount of time and massively reduce errors.
Stair manufacturer
I am very happy with the service. Stairs are a small part of what I do, so will not use the system a lot. I would recommend your product and service to anybody. Thanks
Furniture maker using our StairFile service
I use the free version of StairDesigner and I am in my seventh staircase. I still have two to go. I am neither a mason nor a carpenter, I am an accountant. Even your free software is very useful.
StairFile user
I wanted to thank you for all the help that you have kindly offered me throughout my stair project. Despite my many years experience in woodworking, your expert advice helped greatly with the calculations.
New stair maker
I would like to thank you once again for the advice and personal coaching that you have given me over the last few weeks since I’ve started work on my house and especially the stair that I have built thanks to your StairDesigner software.
StairFile user
I’ve learned a lot thanks to you and StairDesigner and building a quarter turn stair with winders is an ambitious project for an amateur wood worker like myself. Your advice and coaching to set up the plans and all through the build of this project made it a complete success!
Amateur woodworker
Thierry Loeve
Professional StairFile user
"After having worked hard on my stair project it's at last finished and installed. I haven't had any problems building the stair or getting the winders to fit on the turning...thanks to your services and advice..Thanks again for all your help a real God send that saved me hours of work and struggling."
