OptiCut integration with your CNC saw
OptiCut Pro PP includes a range of post processors to convert the cutting patterns into files compatible with CNC saws.
opticut integration with cnc saws
Example integration with the Mayer Kappa beam saw
The video below shows an OptiCut cutting map loaded into the Kappa CNC saw which automatically runs the required cutting sequence. The original test cabinet was designed in PolyBoard.
Here’s a summary of the production process:
  • The test cabinet project is designed in PolyBoard
  • PolyBoard’s cutting list is sent to OptiCut
  • OptiCut generates the cutting maps and the cutting sequence
  • OptiCut sends this data to the beam saw
  • The Mayer saw automatically cuts the parts
  • A label is printed for each part
  • Over to the Felder Creator 950 drilling CNC
  • The label is scanned to automatically load the part file into the Creator 950 (manual option available too)
  • Each part is machined, ready for assembly
OptiCut’s post processor list
OptiCut’s post processors can be accessed from the Import/Export options window via the Tools menu, or go to File menu > Post processor’s format:
Select from:
  • Panels
  • Bars
  • DXF – exporting the cutting patterns in a DXF shape
And then select the specific post processor, the XML (Biesse) panel post processor is shown below.
cnc saw post processors
Here is the Tiger LineCut bars post processor, for use with TigerStop linear saws.
linear saw post processors
The post processor will normally work without any changes, but if required the code can be customised directly from this window. Please contact us for assistance.
Here is the full list of panel post processors:
  • AC/AD
  • AES Alpha
  • Altendorf 1
  • Altendorf 2
  • Canigo
  • Cassadei MC Editor
  • Condal SMH366 V207
  • CPOUT (Biesse, Giben)
  • Demeyere
  • DXF
  • Geometric
  • Homag VIC800S
  • HPGL
  • iLénia (Homag)
  • iLénia 2 (Nimac)
  • iLénia 3 (ACM)
  • KDT
  • Kvara Monolama
  • Macmazza (FMM)
  • Macmazza (PRO)
  • Mayer PC5400 / PC6000
  • Mayer PC7000
  • Nanxing Machinery
  • NPS400 (Homag, Casadei MX)
  • Panhans 1
  • Panhans 2
  • Panhans 3
  • PRV (Schelling)
  • PTX (Homag, Giben) version 1.02
  • PTX (Homag, Giben, Ayza Mizrak) version 1.08
  • PTX (Homag, Giben, Ayza Mizrak) version 1.15
  • PTX (SCM) version 1.14
  • R41
  • R41 / Microvellum
  • SCM MaestroCut
  • SCM Master
  • SCM Master (Imperial Unit)
  • SCM WinCut
  • SCM WinCutPlus 1
  • SCM WinCutPlus 2
  • SCM Xilia Master / X1000
  • Selco NC500
  • Striebig
  • Tai Chan Unik (PSX)
  • TPA (XML)
  • Turanlar
  • XML (Biesse)
  • XML 2 (Biesse)
This is the full list of bar post processors:
  • BTL
  • Default
  • Elumatec (DGX)
  • Elumatec (XML)
  • FOM
  • Mecal
  • RazorGage
  • Ruf (CSV)
  • Salvador
  • Stromab
  • Tiger LineCut
Cannot find your CNC saw on this list?
Don’t worry, we are creating new post processors all the time.
Contact us if you’d like to discuss the possibility of setting up a post processor, or to confirm which post processor relates to your saw.
Please also note that some saws do not offer full CNC automation but can accept the output as a spreadsheet. Haffner Murat saws are one example of this set up.
Where this is the case, OptiCut can generate the optimization results as a spreadsheet to load into the saw.
Output the post processor files to run your saw
Select the Post processor icon to generate the files for your saw.
cnc saw post processor icon in opticut
This command is also available from the File menu:
cnc saw post processor output
Test OptiCut’s post processor output
You can download the trial version of OptiCut and create an optimised cutting map, but it won’t include all the details to allow you to cut the parts. Below you can download a sample optimisation in full.
Click here to download sample files
We’ve included a cutting map for both panel and profile/bar optimisations, along with part by part labels and files for your CNC saw.
Please consider a complementary screen sharing session with us if you would like to confirm the compatibility of a CNC saw with OptiCut. We can also create a new post processor for you if required.
Contact us to request a compatibility test
Additional settings for selected CNC saws
To access these, go to Optimization > Optimization parameters > Post processor:
post processor cutting optimisation parameters
Maximum cutting thickness
Linked to the thickness your saw can accommodate by stacking panels on top of each other.
Strips minimum width
Another machine dependent setting, the minimum width that the saw can accommodate and clamp correctly.
Tension free cuts
Tension can build up in long sections of material. If this is causing distortions in the cutting process, these settings can be used to limit the impact. This feature requires testing for compatibility with your saw.
tension free cuts
Condal specific constraints
Specific constraints required for Condal saws.
condal cnc saw constraints
Fences parameters (Altendorf)
Management of Altendorf specific settings related to the priority between the rip fence and the crosscut fence depending on the part size.
altendorf cnc saw settings
Please also note that there are two different Altendorf post processors. Altendorf 1 relates to older generations of the Altendorf controller, normally, you would be using Altendorf 2.
Mayer specific constraints
Instructions for configuring OptiCut with Mayer saws.
mayer cnc saw settings
Turanlar specific constraints
Built-in configuration for Turanlar saws.
turanlar cnc saw settings
Further saw specific information
We have created some additional resources for specific brands of CNC saws. These can be accessed here:
CNC saw integration
