VCarve Pro software
Multi-purpose CAM software to integrate perfectly with PolyBoard and StairDesigner and a huge range of CNCs.
Plus carving, engraving, moulding, sign making, nesting and many other design and manufacturing features.
This image shows the parts from a PolyBoard project nested in VCarve, with full tool paths set up, ready for output to a CNC machine.
VCarve Pro
Combine with PolyBoard and StairDesigner, our design and manufacturing solutions, to allow you complete flexibility in what you want to build, all automatically output to your CNC in minutes
VCarve Pro's key features
post processors in VCarve
Output for almost every CNC machine
VCarve comes with a huge range of post processors to output the code to run your machine.
If you cannot find your CNC in the list, it is normally possible to create a post processor for you. Please contact us for more details.
Watch the video below to see how fast and easy the PolyBoard to VCarve to CNC integration is.
Fast, simple and automatic integration with PolyBoard and StairDesigner
PolyBoard and StairDesigner come with highly configurable DXF post processors. Once you've finished your furniture or stair design, output the part by part DXF files to VCarve.
VCarve uses a templates system to interpret these files, complete with all tool path and machining details for immediate and 100% accurate output of your machine code.
vcarve and polyboard integration
nesting in vcarve software
Excellent basic nesting function
If you are using a nesting CNC, you must nest your parts so they can be efficiently cut and machined at the same time on your machine.
VCarve integrated nesting module works very well to minimise waste and speed up the cutting process.
Alternatively add OptiNest for a complete nesting solution
If you want full nesting, advanced labels, grain and stock management, it is simple to add OptiNest to your production process along with VCarve.
vcarve and optinest integration
carving features in vcarve
Specialist features for carving, mouldings, engraving and sign making
Ability to design in 2D and 2.5D, plus import of 3D models for manipulation before application of tool paths and cutting. These allow you to create stunning designs additions to your woodwork projects.
For additional powerful 3D modelling features, please consider Aspire.
Plus many more design features
Including an extensive 2D and 3D art library.
Create texture patterns as vectors, apply raised prism machining, cut tapered grooves for a fluting effect, cut out / pocket profiles for inlays and lots more...
vcarve 2d and 3d library
Advanced machining module
Optional add-on to streamline production for cabinet makers
cut list import wizard
Cabinet cut list wizard
The fastest way to get from your design project to nested parts ready for G-code generation.
drill bank
Drill bank support
Customizable toolpath option for all professional workshops utilizing drill bank CNC configurations.
basic label
Part labels
QR and barcode ready labels to facilitate part identification and assembly.
cutter compensation
Cutter compensation
Fine tune your profiling toolpath for reduced tool wear and cleaner machining.
Get your project started today
Download the trial version to test VCarve Pro with your CNC machine
The trial version allows you to load and test a selection of sample projects and then output the code to run your CNC machine. These are available to download with your trial software.
Any work you do in the trial version won't be lost. You will be able to transfer it to an activated version of the software later.
Price includes:
  • Licence can be used on 3 computers
  • Receive 3 months' Wood Designer Premium Support including access to our technical support forum, screen share sessions and many other resources
  • Additional VCarve specific video tutorials, community forum access, email and phone support
vcarve pro download
How to complete your order
Once you've placed your order, you will be supplied with a unique link to register and access your full version VCarve Pro download, plus a licence key to activate it. Please note, you do not activate the trial version.
