MAXI-M3 ATC 2040 CNC Wood Router
+ Polyboard Pro PP + OptiNest + VCarve for seamless design and manufacturing
All-in-one solution, works out of the box
  • Affordable high spec machine and software pack
  • Router working surface 2000 x 4000 mm
  • 8 tool Auto Tool Changer (ATC) with carousel
  • Quality components inc. Japanese servo motors, Italian HSD spindle, and Hiwin rails
  • Polyboard Pro PP industrial level design and fully integrated manufacturing software
  • Our recommended configuration also comes with our nesting optimisation software, specially chosen tools for the woodwork industry and full training
  • Unbeatable warranty and support
cnc wood router
ATC 2040 MAXI-M3 CNC Router
If you buy your software and your CNC machine separately, it can be a major hassle getting them to work well together. No matter how good the support for each individual product is, you are bound to have problems integrating them.
That’s why we provide combined machinery and software, so that you can be up and running in no time; less time on the phone to customer support and more time actually manufacturing.
Wood Designer Ltd has partnered with Maxicam to provide high-end design and manufacturing software that works perfectly with high-quality CNC routers, with little to no effort on your end.
The MAXI-M3 routers are affordable without cutting corners; much like Wood Designer’s software. The standard 10-tool carousel auto tool changers, which are common across our CNC range, are complemented by high performance components including Italian HSD spindles, 850W Japanese Yaskawa Servo Drive Systems and a host of other features for precise, reliable manufacturing.
What is so special about our configuration for the woodwork industry?
This package contains everything you need to get from the first draft to the fully finished product as fast as possible, without loss of quality. Simply, there is no other configuration like this on the market.
  • 1. Polyboard allows you to create fast and accurate design
    It also allows you to generate 3D presentations for clients and automatically generates a cut list with full costs
  • 2. Quick and easy transfer to OptiNest
    To create nesting maps that will minimise cutting time and wasted materials
  • 3. Pre-configured VCarve templates
    Takes just a few minutes to output the code to run your machine
  • 4. Woodwork specialist tool kit
    Polyboard and VCarve have all of the machine tools pre-configured so they don’t need adjusting or customising before you start work
  • 5. Backed up by comprehensive on-site and online training
    So you can hit the ground running
The ATC 2040 will manage very large parts for ultimate flexibility e.g. stair strings up to 4m, and larger furniture parts.
MAXI-M3 ATC 2040 CNC Router
Working area
Italian HSD 9KW air cooling spindle
Japanese Yaskawa 850W servo drive
Taiwanese controller
Hiwin rails
10 tool carousel Auto Tool Changer
3 phase 350 V
4 zone vacuum bed, 5.5 KW pump
3.0 KW dust collector
T-slot table
Polyboard Pro PP design software
VCarve Pro CAM software
Machine install and set up - on site
OptiNest nesting optimisation software
Full training - on site and online
Specialist woodwork tool set and holders
Warranty and support details
  • 3 years warranty on parts
  • 1 year warranty on labour
  • Delivery
  • Installation
  • Onsite training
  • Lifetime CNC support via email or phone
  • Polyboard and OptiNest comes with on site and online training and support
  • Further software support discounted by 50%
  • Extra training packs are available from £350
cnc wood machine
Return to MAXI-M3 OverviewTo view all sizes
Polyboard Pro PPFor further information on the software
Financing available, contact us for more details of our Software/CNC turn key offers.
