Simple intuitive design
Easy to learn design process that is much faster than a traditional CAD package. Size your carcass and drop in your components (drawers, doors, shelves and so on). Resize and the entire model is updated for you.
No need for a specialist technician to work up your projects, perfect for small to medium workshops.
Complex calculations on auto
Sloping walls and ceilings, irregular angles, boxing around pipework are all quick to accommodate. From simple box cabinets to L shaped and corner cabinets to free form designs.
PolyBoard's powerful parametric motor immediately generates 100% accurate output complete with all cut angles every time.
User friendly project management
Drag and drop individual cabinets into a project like a room layout, assess aesthetics, ease of manufacture and resize to fit.
Add single piece or composite worktops, splash backs, plinths and more, all included in the cut list, plans and CNC files.
Single click application of hardware and assembly details
Automatically apply the machining for your hinges, drawer sliders, panel fittings etc based on your own placement rules, plus the exact set up for your drawers, doors and lots more.
Resize your project or change components, all hardware is dynamically moved, added or removed as required!
Huge range of pre-configured hardware and models to choose from or create your own
Also set your preferences for
3D models and flexible order management
One click 3D renders for client presentations, textured, wireframe or semi-transparent . Zoom in, rotate, even open the drawers and doors if you like.
Fast design process allows you to edit on the fly with potential customers.
Cost, material and hardware reports for precise quotations.
Build your own model catalogue for internal use or open it up to customers as an ordering portal (sample models available in our Quick Design libraries).
The perfect design application for residential, commercial and retail sectors.
Production power
Instant access to 100% accurate manufacturing output
Plus integration with all CNCs
Error free design to manufacturing
Created for small and medium workshops specialising in custom projects.
All versions of PolyBoard interface seamlessly with OptiCut, our cutting optimization software
Convert PolyBoard's cut list into a sequential cutting maps to minimise material waste. Full grain matching available. Compatible with manual and CNC saws.
Or combine PolyBoard Pro PP with OptiNest and your nesting CNC
Nest all the parts of your project and send to your CNC with full machining details, labels and grain management.
More great design and
manufacturing features
Flexible tooling operations
Add toolings to your panels, Simple curves to complex shapes. Perfect for curved worktops or shelves, handle cut outs, inlays and pockets.
Frame and panel assembly
Apply any combination of stiles and rails to your doors and drawers, including shaker style façades. All included in your cut list and plans.
DXF import of shapes and plans
Multiple door options
DXF files import, useful for complex room and model plans, or add any polyline for use in PolyBoard's panel design libraries.
Pre manufactured & traditional drawers
Complex panel structures
3D hardware and accessories
As well as including all machining details for your hardware, add handles, hooks and knobs to your 3D models, plus just about any specialist fitting, coat hangers, TVs, ovens, sinks and lots more.
Many more design elements
Everything from plinths, fillers and top rails to sloping divisions and wall cleats/batons. Add to your project as you design or create a model library and simply resize to fit your next project.
Automate production and eliminate errors
PolyBoard not only shows the model in 3D but calculates all the assembly details, parts lists, machine code and price of the project, in real time as you create your design.
Trusted by 1000s of business worldwide
Mark Nichols
The Cabinet Shop
"I would usually allow half a day for pricing and design, two days for manufacture and a day for fitting and re-cutting missing bits and mistakes. That’s 3½ days. This job took 1½ days from start to finish."
Edward Wynn-Jones
Acastrian Bespoke Fitted Furniture
"PolyBoard is fantastic. It has paid for itself many times over and does everything exactly as I want it to."
Adrian Green
Professional designer
"I used to employ a CAD technician to draw up my designs. I can now design a kitchen and get it sent for cutting and assembly in 3 hours, less when I get to know the software better."
Get started today
PolyBoard comes in 2 versions
PolyBoard Pro PP
Lifetime licence
For workshops with CNC facilities, produce all the files to drive your machines
PolyBoard Pro
Lifetime licence
Ideal for professional cabinet makers who don’t use CNC, comes with the complete set of design features
