g-code software|Forum|WOOD DESIGNER
g-code software
August 26, 2016 - 7:08 am
 Hi Michel,
Sounds very good though for the price.
Forum Posts: 990
August 24, 2016 - 11:18 am
Hi Ness
No, Cambam has no automatic g-code from drawing generation. There is a plugins to select same kind of objects. The plugin has a filter you can use for selecting a size of the objects. I.e. you can select all “circle with 5mm diameter” and attach a CAM style.
August 24, 2016 - 5:07 am
Hi Michel,
When you load a dxf file the file is usually layered with each machine operation drawn on a specific layer.
In most CAM programs like Vcarve, ArtCam, AlphaCam, Enroute, etc. you can set up an import template that will look at the layer names and apply a tool path to each dxf object accordingly. So finding a 5mm circle on the appropriate layer will automatically invoke a drilling operation without having to select the circle and choose the tool.
This makes the dxf to gcode entirely automatic and saves a lot of time if the dxf files contain lots of different parts.
Although machining parts with few machine paths as with stair parts placing tool paths one by one is not very time consuming, when machining nested parts it can be long and error prone to have to apply tool paths one by one.
Forum Posts: 990
August 23, 2016 - 5:01 pm
Hi Ness ,
I do not understand your question completely. confused
Can you give me a drawing example that I can use in Cambam ? ( dxf file )
August 23, 2016 - 4:22 pm
Hi Michel,
CamBam sounds like a nice bit of software for a very nice price.
Thanks very much for posting the details here, and I hope it helpful for others using DXF on CNC.
I haven’t had much time to look into the details of the program but it does seem very good.
One question I would have is, can you set up templates that automatically add tool paths too objects on specific layers or do you have to apply tool paths manually to each line, circle, etc.
Forum Posts: 990
August 22, 2016 - 5:01 am
Also you can download this program and have 40 free fully functional evaluation sessions.
After the evaluation period has expired, you can continue to use CamBam to edit drawings and test your post processors and g-code, however g-code output will then be limited to 1000 lines.
So there is no risk at all trying laugh
Forum Posts: 990
August 21, 2016 - 7:07 pm
Hi Ness
I have missed this post . Sorry .
There is little Cambam can’t do 😉 . I use it to create my gcodes for my stairprojects. I have predefined mop’s ( machine operations ) so I only have to select them when I have to . If I knew how to make a video I would do it to let you see an example starting from a DXF file. There are also lot’s of available plugins which are add ons to the program requested by users. I have requeste myself a possibility to create a different gcode for each part on the sheet. It was done in no time and I realy enjoy this program.
May 31, 2016 - 6:01 am
Hi Michel,
Had a quick look at CamBam and it looks really good value.
Does it do auto tool pathing, ie: can you load a DXF file and automatically apply predefined tool paths according to the layer names or other criteria?
Forum Posts: 990
Forum Posts: 990
May 8, 2016 - 5:39 pm
Hi Ness
I found a great program to write gcodes . this is useable for anyone who needs a very good package for any kind of CNC . The forum is very helpfull and skilled people will help to program the postprocessor for the machines . I experienced it myself and it is realy great for a small amount for the license ( around 89 euro only !!!!! ). Program is called CAMBAM . I can recommend this to anybody. It is that good !!!!! believe me. I am using it and it is very user friendly , professional and as far as I am concerned there is almost not limit on this software
check it out !!!!
Here is a screenshot of my version
Guest(s) 24
Patrick Maylor: 62
Topics: 2103
Members: 260
