Importing Polyboard to Opticut|Forum|WOOD DESIGNER
December 12, 2014 - 7:08 am
Hello Archana,
If Opticut says no available panel it means that it hasn’t found the panel in the stock.
Make sure that each item in stock has the exact material name associated to it.
If the material name associated to your panel in stock is not spelt the same as the material in the library and the material in your cutting list Opticut will not be able to link up the list with the material and the stock.
The easiest way to do this is to take the cutting list and if necessary, restore the material to the materials library from the list, then when setting up stock select the material from the the existing materail library . this makes sure that there are no typos and the whole process will flow.
Hope this is clear…here’s a quick video that shows how to set this up:
To see how to set up Stock look at this video:
Stock Set Up
December 12, 2014 - 6:38 am
Hello Ness,
Thanks so much for your reply.
In opticut i made all possibility on cutting list options are set,Material setup, Stock setup. But my Initialization says No available panel. Is there any way, I can do this better way. I have attached my storage unit for your guidance.Please guide to proceed I’m stuck.
Thanks,
Archana.MJ
Guest(s) 49
Patrick Maylor: 62
Topics: 2104
Members: 260
