Hi Mohamed,
When incorporated into a structure, a copy of the bar materials will be stored in the actual structure of the cabinet with it’s parameters when it was copied. These will be fixed when the cabinet is saved and not update with the changes in the libraries.
Can you post your project file on the support forum so that we have a look at it?
Please note that this section of the forum is for general questions only.
best regards,
Mohamed hamza
December 25, 2016
Dear Mr. Stefan
When i make a cabinet with a plinth and this plinth is an assembly construction as a bar material
the problem is when i change the name of this bar material and its price from main library it dose not reflect on all the cabinets
so i must reopen every cabinets again and replace it manually . this happens in the bar material only .
i attached a photo for this .
so please is there any solution ??
