cut strings drawings|Forum|WOOD DESIGNER
March 7, 2017 - 2:59 pm
Hi Jesper,
The anchor point looks fine.
Here are the working documents for your stair.
I wish you good luck for the build, and love to see some photos if possible.
25
March 7, 2017 - 11:35 am
Hi Ness they are identical it was just a mistake and just change it to 200mm. did you find out anything with the anchor position ??
And on the picture you just sent. it does not look like it is in 3 parts. can you send a picture from above.
Cheerslaugh
March 7, 2017 - 11:08 am
Hi Jasper,
Thanks for posting these 2 stairs, both models look the same to me.
Am I correct or if not which one would you like processed?
One remark, your cut strings are 300mm wide under the step notches, this is not really necessary.
Structurally you don’t need more than 180mm, the stair then looks lighter and uses less wood.
final01v01.jpgImage Enlarger
cheers,
23
March 6, 2017 - 5:08 pm
Final stair
22
March 6, 2017 - 5:05 pm
Hi Ness anchor position is 17 cm and floor thickness is 34.6 cm
I do not understand the anchor position but hope you can get something out of what I have written
I have made a landing step and put in the right measures they are 265,1 cm and 282 cm
so now I think I’m done and if you do not have anything to add, you can send the files
21
March 6, 2017 - 11:57 am
hi ness should I attach the stairs to the concrete floor and so make the bottom step a little higher?IMG_20170306_121721-872x872.jpgImage Enlarger
all the other measurements i look at when I come home from work
March 6, 2017 - 5:49 am
Hi Jesper,
This stair doesn’t have a landing step and is not the last version I have.
I attach the last version which has a total height of 2648, compared to the version you just posted at 2640.
Note that it’s usually better to make the stair a little higher than shorter.
Note also that the vertical width of the cut string as it meets the joist is 384 and the anchor height where you’ll have to fix the stringer into the joist is in the lower half of this. So you have to check the total floor thickness and make sure that this is possible given the position of the main supporting timber .
first-floor-joist.jpgImage Enlarger
arrival-010.jpgImage Enlarger
Can you make any necessary adjustments to the stair I’m posting and validate the project for processing?
19
March 5, 2017 - 10:07 pm
Hey Ness, I think this is the final design but I’m not quite sure 🙂 do you have anything to add? the stair are maybe 3 mm higher but if I press it into the program so it will have 15 steps and I would rather avoid
March 4, 2017 - 9:19 am
Hi Jesper,
Before I send you the manufacturing documents and so that there is no confusion in the file we process, can you post your final and validated project sds file to the forum.
Thanks,
17
March 3, 2017 - 9:42 am
yes I’m a little busy because my bank is up my ass ? but that’s okay it will not be this week. but I hope it may be early next week?
Guest(s) 39
Zaheer Abbas: 89
Patrick Maylor: 63
sales@pinestation.co.uk
wstenholt@gmail.com
Michael Hofer
Chris Jackson
Anthony Penn
almys111
Topics: 2110
Members: 266
