Stair file lite|Forum|WOOD DESIGNER
Stair file lite
October 22, 2015 - 6:02 am
Hi Daniel,
Here are your new files.
October 19, 2015 - 8:31 pm
sorry I did forget. Here is the file.
Many thanks!
Daniel
October 13, 2015 - 3:09 pm
Hi Daniel,
The bolts have a wood thread screwed into the stringer or handrail and a nut and washer on the post.
I can’t see your sds file, did you forget to upload it?
October 12, 2015 - 2:20 pm
Another stair file lite request. I’ve had to make mods but it’s pretty much the same. I saw your video on dowel and bolting carriages/ stingers but was wondering on what you used to attach the bolt to one side?
I know it that the lite file request is once per month but is that per calendar month or  one month from the last request.
Many thanks
Daniel
September 22, 2015 - 3:35 pm
Hi Daniel,
Here are your working documents.
Your design is a bit original but should work fine.
Note that as you have cut strings, StairDesigner doesn’t draw the joint lines with the posts, so you’ll have to add these to the dxf files or directly onto the boards once marked up.
good luck with the building and keep me updated as to how it goes.
September 22, 2015 - 10:02 am
I’ve made a few tweaks on your suggestions and think this would work best for me. Could I request a stair file lite please. I’m not sure if a pro would be best at this point but i’ll give it a go and see
Daniel
Guest(s) 48
Patrick Maylor: 62
Topics: 2104
Members: 260
