My first stair|Page 2|Forum|WOOD DESIGNER
I dont want a post on arrival, i have walls on both sides there, so i dont want any posts there.
ok about the mid steps.
It was meant to use the well size, but i didnt know how to. But if its 920mm between the stringboards (outside) on arrival, it is ok.
The length of the well is totally 3420mm, so maybe i should have a clearance of 5mm ?
thanks
Hi Sig,
Your new stair looks good.
The only questions I would have are
– I don’t see a post at the arrival is this normal?
Otherwise the stair has been set up using the inner dimensions and it usually would be better to use the outer or stair well dimensions and let StairDesigner calculate the inner sizes.
In the attached example I’ve added a last post and adjusted the mid steps to straight, this is just not to have steps that are very slightly tapered which can make sorting pieces confusing.
If there is no problem I can send you the manufacturing files .
Hi Stig, thanks for posting your project details. Ness will reply soon. All the best, Stefan
Thanks for ordering your StairFile. Please post the design and specifications you have for your new project when you are ready.
Stefan said
Hi Stig, can you buy the StairFile on this page as before: https://wooddesigner.org/membe…..discounts/…and post your project details here. Thanks very much, Stefan
Ok, i just did 🙂
H
Ness said
Hi Stig,I’ve changed the StairDesigner model of you stair so that the steps are recessed 15mm and notched around the posts.
Here are the new DXF files, hope this is helpful.
Note that you will have to adjust some steps and reduce the recess as in this example….
You have to cut the step so that the notch doesn’t wrap around the post and not recess the string.
Hello Ness,
I would like to buy some DXF files(plans) for same stair, only with new measurements ( for 2nd floor)
