oversizing panels|Forum|WOOD DESIGNER
oversizing panels
Forum Posts: 1942
May 3, 2024 - 1:00 pm
When you oversizing par like this that just said how much you want add on parts for pre-cut to calibrate on CN (height / width /2 per edge),
In other words, it does not oversize parts to fit them when they are installed on your customers’ premises, for example.
To oversizing panel you can edit shape manually, or add negative recess value
single-pan..pngImage Enlarger
michael hibbins
Forum Posts: 13
April 20, 2022
May 3, 2024 - 10:32 am
hello Alex,
im using 7:10k, I can see there there is an updated version-7:10u, ill install this one.
ill attach the project, its the end panels we’ve tried oversizing.
many thanks
michael
Forum Posts: 1942
May 2, 2024 - 11:39 am
Can you upload your project and tell me which version you’re using?
The tests carried out with the latest version did not show any anomalies.
michael hibbins
Forum Posts: 13
April 20, 2022
May 2, 2024 - 10:22 am
hello there,
when oversizing panels(end panel and fillers etc) from the properties menu, we get it come through on the cut list as it should but doesn’t go to the Cnc with the oversizing, is there a way of doing this so it does please?
many thanks
Michael
Most Users Ever Online: 365
Guest(s) 25
brendan kavanagh: 165
Tom Cleaver: 164
mark nichols: 162
Conor Devoy: 158
Zaheer Abbas: 129
Blake Simpson: 104
Tom Jackson: 78
Patrick Maylor: 75
Salman Bukhari
Rhodri Morice
LORIN STANCIU
luc smiechowski
harry tattersall
Adam Lee
Ruan Pienaar
omech
vitocarpentry
publisher_backroom543
Topics: 2435
Members: 370
