2" x 4" frame with plywood shelves|Forum|WOOD DESIGNER
November 18, 2015 - 7:05 am
Hi Leonard,
Sorry but I don’t really understand your construction.
If I get the gist your project is made of a couple of solid wood frames with shelving between. If this is correct it should be OK to design with Polyboard.
However please send at least a sketch so that I can understand correctly what you have in mind.
November 17, 2015 - 1:52 am
I don’t have a file. The unit would be 7 feet high, 8 feet long, 2 feet deep. The frame would be made of 2″ x 4″ and the 3 shelves would be equal distant apart.  The 1/2″ plywood would be attached to the 2 x 4 shelf frame.  Each shelf would be 2 feet deep and 8′ long and the height of each shelf would be 4″ (the 3.5″(height of 2×4) + 1/2″ (plywood)).   The 4 uprights to support the shelves would be 2 x 4 x 7′ high.  Will the description help.
Len
November 16, 2015 - 7:16 am
Hi Leonard,
I can’t see your units, have you forgot to attach a file?
To attach a file click the Upload Attachments button below, drag and drop the file into the window and then click the “start upload” button.
November 15, 2015 - 9:11 pm
Hello my name is Len.  Can I design these units using polyboard software?
Guest(s) 17
Zaheer Abbas: 88
Patrick Maylor: 63
Anthony Penn
almys111
Topics: 2107
Members: 262
