Cabinet with face frame, toe kick, and sides that go down to the floor.|Forum|WOOD DESIGNER
February 7, 2017 - 10:37 pm
this looks perfect.   I’ll give it a try.
Thanks,
Andrew
February 7, 2017 - 10:21 pm
Hi Andrew,
To trim the uprights select the side panel and click the  “Assembly>edit button”
structure_edit.pngImage Enlarger
Then set the lower cross bar over lap to the trimmed height of 101mm.
This will make the side panel overlap by 101mm the bottom so to get it back into alignment,  set the side to bottom overlap to 0.
structure_edit-020.pngImage Enlarger
This will give the correct length to the side and face frame.
Please note that we are actually tricking Polyboard into making face frames by using the Assembly structures in a round about manner.
As you are using the Quick Design face frame method, this maintains the method and will make a face frame that allows you to add separations, doors, drawers, etc.
face_frames_020.pngImage Enlarger
I attach your adjusted model so you can see how it’s been set up.
We are hoping to add a better face frame management in later version updates but this is a lot of development work so will probably not be available for sometime yet.
Hope this is helpful.
Forum Posts: 1964
February 7, 2017 - 8:04 pm
Sorry, Free member can’t download files
Capture01.jpgImage Enlarger
Capture02.jpgImage Enlarger
the easy way U must using door Structure->edit…>Assembly.. to create frame
Or apply to door Quick Design Library structure
Forum Posts: 1964
February 7, 2017 - 7:48 pm
if I understood correctly,
it must look like this,
I use a translator so the translation is sometimes funny….
February 7, 2017 - 4:26 pm
Oops, looks like the file got uploaded twice.  it’s the same file.
February 7, 2017 - 4:16 pm
Here you go.
Thanks,
Andrew
Forum Posts: 1964
February 7, 2017 - 10:29 am
hi, Can you post your cabinet?
thx , Alexandre
February 6, 2017 - 9:34 pm
Hello-
I’ve been playing around with your software for a few days, testing it out.  I was wondering if there is a way to trim the face frame so that it doesn’t extend through the toe kick (see attachment) to the floor? I thought maybe I could use a tooling cutout similar to the one I used on the side panel, but it doesn’t look like I have the option to use that function on the face frame.
Thanks for your help,
AndrewPicture1.jpgImage Enlarger
Most Users Ever Online: 365
Guest(s) 28
brendan kavanagh: 179
Tom Cleaver: 164
mark nichols: 162
Conor Devoy: 158
Zaheer Abbas: 132
Blake Simpson: 104
Patrick Maylor: 84
Tom Jackson: 83
Rick48
Hassan Sultan
Carmela Di Sorbo
Telmo Oliveira
Jesus Vergel
eduardo beiza
lucas Lucas Moreno
Efthimis Stathas
Rayallie
Topics: 2513
Members: 393
