Front of Drawers with cut |Forum|WOOD DESIGNER
the most optimal way would be to create a custom open curve in any CAD program and make a new edges tooling out of it ( Libraries > Open curves – here load your custom curve and then apply by clicking on the drawer front then Properties > Drawer# > Structure[Edit..] > Edges Tooling ).
I made it just in polyboard but needed to combine Edges Tooling (with one of Polyboards default curves) with Single Panel fittings – not optimal since the final result is achieved with 2 operations. Also Single Panel Fitting in my case is a groove operation which creates a centerline toolpath – which requires you to think about precise tool diameter.
Hope that helps 🙂
Guest(s) 50
brendan kavanagh: 236
Emmanuel Sacco: 210
Zaheer Abbas: 201
Tom Jackson: 142
Rooms Made Simple: 132
MobLux
Valentin Zarzara
Kendal Anderson
Sarah J0hnson
Andreas Nygårds
Nicolas LEBRETON ROOST
Luka Savić
Lee Gent
A S Brighton
Tobias Briander
Topics: 3062
Members: 602
© Simple:Press —
