Internal Drawers|Forum|WOOD DESIGNER
i have deleted your 60mm shelves and i have replace them by 2 nil shelves
space with 60mm for 3d
OfflineHello,
when you add an object like a shelf or a vertical partition then it becomes a reference for the parts add after as a drawers and can not be removed anymore
PS I allowed myself to change the connections on the small drawers between the sides, the face and the bottom
All the best Alex
D-Alexandre said
Hello,If you did not use Quick Design before, no problem!
2 solutions
1 * Redefine the default folder of Polyboard before installation of Quick Design if you have not changed original (see attached image)
2 * That I advise you, restore your methods from previously made furniture (see example)
PS: don’t forget the little yellow star, thx 😉
Thanks – ill think ill wait til i speak to Ness on thursday as i dont want to loose anything else – all my manufactoring method have gone too
OfflineHi Elliot,
I send you a mail to arrange the training session.
Best Regards,
Carole
OfflineHello,
2 solutions
OfflineHello,
All Tandem slide for wood Draws are comptaible with Fittings
associate with “Blum/drawer-Tandem//cab/z” rules
Have you install Quick Design Pro on [Subscribe to Premium Support to view this media]
PS. For new wood draws Ta’or Box you need to use Lagrabox fitting with Movento Slide!
