Grain Matching when want multiples of a unit|Page 2|Forum|WOOD DESIGNER
Adjusting quantities in Optinest can not maintain grain matching as the matching information is exported by Polyboard to Optinest.
Exporting a quantity in a catalogue should work though.
To see why this is crashing can you post the Polyboard project and catalogue files.
Thanks,
We have a smaller kitchen that we need to make 27 of them. We want the doors to be grain matched on each of the cupboards. This is working totally fine when we just have the single export of each component. see below.
When we then change the quantity to 27 to stops following the grain matching rule and just does each component separately. Is there a setting somewhere I am missing?
I have also tried drawing the units we want matched to be a single profile (by editing the DXF file and adding little bridges between the parts I will then need to remove later). This has worked but seems an extra step.
I have also tried to add all of the components into a catalogue file and export the 27 matches pairs there but the program just crashes so doesnt get me closer.
