How to use CSV file on Opticut for Optimization |Forum|WOOD DESIGNER
James Singh
Forum Posts: 14
November 11, 2019
August 24, 2023 - 2:39 pm
Hi, Alex
Now this barcode error is resolved, Thanks
Forum Posts: 1909
August 24, 2023 - 2:30 pm
Not sure,
Did it work before?
Did it always work from project export from your PolyBoard?
Is it specific to this import?
If the answer to the first two questions is yes, this probably means that some fields, automatically filled in by PolyBoard, are not filled in this import, such as the furniture name, or cutting list numbers, which may not be necessary in your current label configuration.
add-ref.pngImage Enlarger
Cheers, Alexandre
James Singh
Forum Posts: 14
November 11, 2019
August 24, 2023 - 10:25 am
James Singh said
Hi Alex, while generating a barcode on the Machine we are getting this kind or error, could you please help in that matter as well?
many thanks
WhatsApp-Image-2023-08-24-at-14.07.57-1.jpgImage Enlarger
James Singh
Forum Posts: 14
November 11, 2019
August 24, 2023 - 10:23 am
many thanks
Forum Posts: 1909
August 23, 2023 - 2:58 pm
I think your file is still open in the spreadsheet software, or text editor.
Please, Closed them before Import
James Singh
Forum Posts: 14
November 11, 2019
August 23, 2023 - 2:47 pm
Thanks for your support, now we are having trouble while importing files could you please check? and let us know what we need to do. Opticut.pngImage Enlarger
Forum Posts: 1909
August 23, 2023 - 1:31 pm
OptiCut is able to import any CSV files, but you need to know export format, to update your import format,
each column should be separate by single separator,
Luckily, your CSV seems to be clear to understand.
quick opening your CSV files with text editor show the separator is a comma “,”
text-edit.pngImage Enlarger
now you are able to import into sheet software like excel or Openoffice and set separator to comma
and the good news is that every column is described!
column.pngImage Enlarger
Start news cutlist from OptiCut then select import option
import-option.pngImage Enlarger
and set Separator and if need Decimal separator,
click on format
final edit column “Fields to be imported” with column “Available elements”
They can be added/removed by double-clicking, and sorted by holding down the click.
For unused fields, select the “Ignore field” option, and don’t forget any field!
setup.pngImage Enlarger
And If you need more field you are able to add news fields from menu Tools > preferences
fields.pngImage Enlarger
If all is ok, import your CSV file
test-2.pngImage Enlarger
import-format.pngImage Enlarger
Hope that’s helpful, Alex
James Singh
Forum Posts: 14
November 11, 2019
August 23, 2023 - 12:09 pm
Hi, Greetings from Metro Wardrobes. One of our Designer send us CSV file. as he’s using Sketchup for generating these files. we are not able use these on our Opticut for Optimization. could you please check and let us know what we need to do.
Most Users Ever Online: 365
Guest(s) 48
brendan kavanagh: 153
Conor Devoy: 146
Zaheer Abbas: 117
Blake Simpson: 104
Robert Coxhead: 74
Patrick Maylor: 73
razvan george tomas
Dennis Nwachukwu
Richard Maursky
sean mcmullan
James Shepherd
matthew fier
JEROME BRIERRE
Zaki Brijawi
Paul Glavin
Girts Martinsons
Topics: 2298
Members: 342
