nesting using different size panels|Forum|WOOD DESIGNER
brendan kavanagh
Forum Posts: 226
September 26, 2023 - 5:58 pm
Thank you Alex and Michel that is now working
Caroline laugh
September 26, 2023 - 5:26 pm
Hi Caroline,
As explained via email, untick the box called “test all panel formats” in the optimisation parameters. This forces Optinest to follow the panel priorities under the condition that the parts fit on the smaller panel.
on-parameters.pngImage Enlarger
brendan kavanagh
Forum Posts: 226
September 26, 2023 - 3:39 pm
I have uploaded file
Caroline
Forum Posts: 2110
September 26, 2023 - 3:31 pm
Can you saved and upload your nesting (*.nst) from OptiNest
brendan kavanagh
Forum Posts: 226
September 26, 2023 - 3:05 pm
Hi Alex
Sorry not really understanding this, maybe have to do a zoom call with Michel
What file do you want uploaded?
Forum Posts: 2110
September 26, 2023 - 2:34 pm
Hi Caroline,
You are talking about 2 different things
Firstly, the priority in the panel stock allows you to define which panels should be used first.
Secondly, the priority of panels to be machined is used to sort the parts from each other.
Case 1 : 2 Panels format – All parts with same priorities
OptiNest Used panel according Priority of panel stock
Case1.pngImage Enlarger
Case 2a : 1 Panels format  – Top & Side Priority “1”, Side Priority “2”
and depending on your optimisation “Priority Management”
case-2-0.pngImage Enlarger
At 0 OptiNest is authorised to mix parts with different priorities on the same panel.
case-2-0a.pngImage Enlarger
To simplify at 1 and 2 OptiNest adds parts in order of priority 1,2,…..If a part with a lower priority cannot be placed
At 3 OptiNest is not authorised to mix parts with different priorities on the same panel.
(This most used to sort parts with turn around, like Vertical division)
Naturally, the parts must fit within the specified format, height and width, as well as any other constraints related to the direction of the grain that would prevent the parts from rotating.
Please upload file may I miss something,
brendan kavanagh
Forum Posts: 226
September 26, 2023 - 12:14 pm
Hi
I am nesting a job with 2 different size boards 1st is 2650 x 480 (9 boards to use) and 2nd 2650 x 1615 (unlimited)
want to use the 9 boards first then use the othersScreenshot-8.pngImage Enlarger
please see screenshot attached from optinest i have set the 9 boards as no 1 priority and others as 2nd but only 1 board of the 9 is nesting, have i not done this right could you advise asap
Thanks Caroline
Guest(s) 69
Emmanuel Sacco: 176
Zaheer Abbas: 173
Tom Jackson: 124
Mounib osman
Sebastian M.
Tom McGranaghan
Mohamed Mekayed
Juan Carlos Izquierdo Hdez
Taras Orlyk
Jacob McKay
Juho Simuna
Nahuel Sena
Björn S
Topics: 2849
Members: 516
