Not able to optimize CSV Files |Forum|WOOD DESIGNER
OfflineLike explained on my previous message,
You make choice of restore materials, then you need to create panel using this news materials
1 – I have re-work import format with this all should incoming in the right fields
2- You can’t leave materials grayed out, because that means they’re not in your libraries and optimization can’t be done.
-Click on the field header to sort by type, then select several lines to batch-modify them with those in your libraries.
-Or, restore it to your libraries with a right-click, but be careful: if you restore it, you’ll need to create a panel for these new materials, and define an edge thickness, even at 0mm.
Cheers, Alexandre
Guest(s) 42
© Simple:Press —
