Optinest cutting parameters|Forum|WOOD DESIGNER
Graham MacRae
Forum Posts: 33
March 24, 2023 - 8:45 am
Hi Alex,
Thanks for the info much appreciated. Always good to get a better understanding of the system settings.
Many Thanks
Graham
March 23, 2023 - 10:29 am
Please see my favorite setup for cabinet
ON-para.pngImage Enlarger
– We recommend setting the default part to the opposite side of your original CNC to save and reuse your off-cut more quickly. (Green arrow)
-To favour identical parts you can also work with the properties (Red Arow)
With the 3 out of 4 option the pieces of the same property will be mostly on the same pattern
With the 4 out of 4 option the pattern will have exclusively pieces of the same property
This properties are export by PolyBoard by default to
– 1 for single face tooling
– 2 for two faces tooling
By selecting a part you can for example forbid the rotation, and define an identical property to be exclusively on the same panel and in the same direction which will then give very homogeneous panels
sample.pngImage Enlarger
hope that’s helpful, Alex
Graham MacRae
Forum Posts: 33
March 22, 2023 - 5:32 pm
What parameter setting in Optinest would best position the parts to only be separated by the cutter thickness, this would make it easier to apply tabs to the toolpaths.
Graham
Guest(s) 39
