Oversizing being applied but not considered when nesting.|Forum|WOOD DESIGNER
Forum Posts: 1029
July 27, 2023 - 10:13 am
Hi Matthew,
this was solved in our zoom session of today
Matthew Murphy
Forum Posts: 41
February 8, 2022
July 27, 2023 - 8:10 am
Hi Michel, thankyou for getting back to me, so the only menu I can find to input similar parameters is create a new optinest file > parts > Import DXF parts > import the parts then this interface comes up.optinest-DXF-import.pngImage Enlarger
unfortunately It did not work, it brought up this error message optinest-error-message.pngImage Enlarger
Here is the text i entered for each parameter from what i could see on the screenshot supplied.
Outer and inner outline layers
CONTOUR*;0;panel
Toolings Layers
/*.CHANT*;/EDGE.*;/PANEL*;/PANNEAU*;/outline*
the full stops before CHANT and after EDGE did not seem to fit the pattern so I also tried this
CONTOUR*;0;panel
Toolings Layers
/*CHANT*;/EDGE*;/PANEL*;/PANNEAU*;/outline*
Just in case it was a typo.
Thankyou for your help as always. will be great get this sorted.
Forum Posts: 1029
July 26, 2023 - 5:38 pm
Hi Matthew,
In PolyBoard, the oversizing applies to the base panel and not to the part outline.
Therefore if you wish to output oversized parts in OptiNest, you must set your import
so that the imported part is the Panel layer, not the Outline layer.
optinest-oversize.pngImage Enlarger
Matthew Murphy
Forum Posts: 41
February 8, 2022
July 26, 2023 - 8:03 am
Final images
Matthew Murphy
Forum Posts: 41
February 8, 2022
July 26, 2023 - 7:57 am
optinest-example.pngImage Enlarger
Matthew Murphy
Forum Posts: 41
February 8, 2022
July 26, 2023 - 7:54 am
Hi, I am having trouble outputting oversizing currently on plinths and cover panels etc. I am thinking the problem with either with my post processor options on polyboard or one of my settings on optinest. So if you look on the optinest image is shows the net size and then what must be the oversizing.
Any help would be appreciated as i need to get this turned around today.
Thankyou in advance.
(jpgs wont load in this post will upload in a reply)
Most Users Ever Online: 365
Guest(s) 19
Tom Cleaver: 164
brendan kavanagh: 156
Conor Devoy: 146
Zaheer Abbas: 122
Blake Simpson: 104
Robert Coxhead: 74
Patrick Maylor: 74
Andrej Potočnik
Olga Safari
Greg Allen
Maximo Vinet
ben levene
roni ben ami
Kateryna Druzenko
Joseph El Hajj Moussa
razvan george tomas
Dennis Nwachukwu
Topics: 2345
Members: 350
