Part rotation on label in Optinest|Forum|WOOD DESIGNER
Graham MacRae
Forum Posts: 33
May 30, 2022 - 2:24 pm
Hi Michel,
Thanks for getting back to me. I’m available anytime tomorrow so please set the meeting for a time that’s convenient for you.
Many Thanks
Graham
May 30, 2022 - 8:12 am
Hi Graham,
We can have a short session tomorrow if you like. Sorry for the delay in the answer. Let me know what time frames you can be available and I will send you a zoom link for the session
Graham MacRae
Forum Posts: 33
May 13, 2022 - 4:04 pm
Hi, could we arrange a screen share support session to check settings as this issue is very frustrating.
Forum Posts: 2110
February 8, 2022 - 10:34 am
I’m sorry,
I’m not sure I understand,
on all the last tests carried out this last day I have not had any anomalies.
Even with manual rotation of the parts all seems to match, using the PP optinest with your parameters
I’m not sure but it depends on your setting.
The only anomaly I could see was in the screenshot below where the rotation was reversed.
But to have the same thing between the DXF and Optinest output, and depending on the screenshot you don’t use the same orientation settings
un DXF you using “Conventional” instead of “Grain direction (Vertical)” like optinest
GD.pngImage Enlarger
To upload the files here you can compress them in *.zip before
it’s also easier to follow here than by mail
All the best, Alexandre
Graham MacRae
Forum Posts: 33
February 3, 2022 - 10:02 am
Sent by mail
Forum Posts: 2110
February 3, 2022 - 7:59 am
can you upload optinest files .nst and Polyboard cabinet?
Graham MacRae
Forum Posts: 33
February 1, 2022 - 7:56 pm
Hi Alex,
Thank you for the info. I understand what you have shown below and my settings are as per your recommendation but the issue is the writing on the label is no longer the correct way up for vertical panels since updating to 2.32a. I have attached a couple of images to show how it was before updating with the information on the label the correct way up for the left hand panel and the second after updating with the image showing the information will be upside down when assembling the cabinet.
I appreciate this is not a big issue but makes life a little bit easier especially for doors and vertical panels.
Screenshot-2022-02-01-192549.pngImage Enlarger
Screenshot-2022-02-01-191501.pngImage Enlarger
Forum Posts: 2110
February 1, 2022 - 8:20 am
You can make Quick test with cabinet attached,
Now in optinest make the machining appear
Toolings.pngImage Enlarger
After that always for the understandings test, activate on the labels, the shape, the machining and the rotation
The rotation is always counter-clockwise from front/Right Edge
Rota.pngImage Enlarger
labels.pngImage Enlarger
Hope that’s helpful!
Graham MacRae
Forum Posts: 33
January 30, 2022 - 12:21 pm
I now understand the rotation of the part on the nest in relation to the label.
After the parts are machined is there a setting to have the information on the label (references) to be the correct way up, this would be particularly useful for vertical panels that have the same tooling.
Graham MacRae
Forum Posts: 33
December 18, 2021 - 4:41 pm
Hi Alex,
Thank you for the explanation.
Cheers, Graham
Guest(s) 42
Emmanuel Sacco: 179
Zaheer Abbas: 175
Tom Jackson: 133
Beth Hinks
Manuel Belmar
Colin Rouse
Steven mason
Chas Joy
Eduardo Montilla
Mounib osman
Sebastian M.
Tom McGranaghan
Mohamed Mekayed
Topics: 2874
Members: 522
