Pre-milling settings Opticut/Polyboard|Forum|WOOD DESIGNER
This solution is for new project and should required new cutting list export!
But also make sure that your edges are synchronised with the OC and the update of the previous project.
You can be sure that if they have arrived at the OC, they must be written in black in the list and ‘not in grey italics‘.
It is also possible to restore edges in OC and then set it to zero.
After it always better to control this quickly, and look if Polyboard and OptiCut using the same Materials folders,
this ensures that the panels and edges are properly synchronised
From PB and OC from menu Tools > Folders > Parameters > Line Materials
Hope that’s helpful, Alex
Guest(s) 25
© Simple:Press —
