Struggling to optimise|Forum|WOOD DESIGNER
OfflineHave you received my mail?
Can you give my your Opticut file? (in a zip folder for upload here)
OfflineHi tom,
You recently changed the Maximum Recut level?
Can you change this value to 3 or 4 ?
All the best, Alexandre
Tom Cleaver
Forum Posts: 166
May 18, 2014
OfflineHello,
I have sent a model to Opticut and the results are confusing. Opticut is using more sheets than required and I have no idea why? The model I have attached shows 22mm MRMDF that could easily be cut out of one sheet. However Opticut is splitting them over two. This is also happening on other models and materials. Changing the parameters does not seem to make any difference.
Kind regards
Guest(s) 41
Conor Devoy: 173
Jan Peter Oelen
ANDI MÖÖBEL - Tarmo
Topics: 2964
Members: 562
© Simple:Press —
