Angled unit|Forum|WOOD DESIGNER
May 12, 2020
Hi Alex
Just one thing we are adding an adjustable shelf to this unit so i need to apply regular drillings to left back, right back, left side and right side. I add a double back no hardware as i would normally to do the back drillings it doesn’t seem to work could you send video please
Thanks Caroline
There is a slight subtlety to what you want to achieve
In FreeShap mode or angled cabinet the dimension is the overall cabinet
This means that 300 mm at 45° in 18mm exterior will give 318mm.
From what I understand, you need 300 mm but start from 282mm (282 + 18mm of 45° that we will add later).
Hope this video helpful
Hi
Please see attached sketch and angled unit i have started on polyboard, as you can see on sketch need the distance from front to back to be 850mm with the 50mm overhang from side gables
I have started it in polyboard but i cant get the 850mm at the back can you help? Also gables should be 300mm but are 318mm? Please send video of how this can be done
Thanks Caroline
