Auto device dimention after edging|Forum|WOOD DESIGNER
Hello Hung Vu,
Yes, PolyBoard takes into account your edge thinkicknesses. If you go to Cutting Lists > Cutting List Options, you can change the setting to Net Dimensions. Now, PolyBoard will shrink the panel to the corrent dimension. If you set it to Overall Dimension – Polyboard will ignore your edge thinknesses
Just so you know: you can set edges to be negative values, then PolyBoard will make your parts bigger (overdimension) – might be usefull
Best Regards,
Rafal Meckovski
Hello
I used demo version so i can check dimention of drawer or door after apply. So have a question
Example: I have 2 drawer (300x400mm) with SLACK of them is 3mm – after edging banding 2mm for drawer – Can The PP auto calculate device 2mm per drawer? (mean: panel of drawer have just 298 x 398 mm) – I think it’s very important – if not dimention will be 302x402mm – maybe Not SLACK when assembly – 2 drawer stick together – can not assembly
If PP can auto do that – Please tell me how can do that
Thanks alot
