"Box cabinet" with different heights for side1 and side2|Forum|WOOD DESIGNER
Forum Posts: 1592
sp_UserOnlineSmall Online
April 26, 2024 - 8:11 am
Hi Venugopal N. Sorry for the late reply.
The overall dimensions of your cabinet will stay the same when making these changes. Therefore, you will need to allow for this in your cabinets height in the properties window. Please see attached image.
image-3.pngImage Enlarger
Pravara Modular Industries LLP
Forum Posts: 17
April 24, 2024 - 12:03 pm
When I do the way, you mentioned. The height of the side is not increasing. But the height of the cabinet is reducing. wink
That is still ok, I can adjust the size while creating the box.
Thank you.
Venugopal N.
Forum Posts: 1592
April 24, 2024 - 11:45 am
Hi Venugopal N,
Here is a way to achieve this. If you select the side you would like to make longer, select the ‘bottom link’ in the properties and overpass by the desired amount. Please note that the total height in your dimensions needs to allow for this. Please refer to attached image.
image.pngImage Enlarger
Let me know if you need any more help.
Forum Posts: 17
April 24, 2024 - 11:31 am
PFA..
attachment was missing in my earlier reply.
Image1.jpgImage Enlarger
Forum Posts: 17
April 24, 2024 - 11:24 am
While we make box cabinets for kitchens, for the first and last cabinets we will extend the sides by the height of the plinth. This way there won’t be any joint visible from the sides.
I made a small drawing and attached with this. Please check it and let me know if you need any more clarifications.
Thanks & Regards,
Venugopal N.
Forum Posts: 1592
April 24, 2024 - 8:45 am
Hi Venugopal N,
I am just trying to understand exactly what you are needing, do you have an image of what you are trying to achieve?
Thanks,
Forum Posts: 17
April 24, 2024 - 8:15 am
While creating a "Box cabinet" I would like to have different heights for side1 and side2. Taller side will act as plinth on one side and PVC legs are attached below side2.
In the front a regular plinth will be added.
How can I achieve this?
Thanks & Regards
Venugopal N.
Currently Online: Fatima, Isaac
Guest(s) 58
Christian GLENET
mohammadmaghari
Petru
Trojan Construction
Islam Boukouiren
Topics: 2970
Members: 566
