We have had this happen on a few different units now but when having a recess behind a door you often need to half the amount you really want the panel recessed. In the example below we want the panel to be 2.5mm recessed behind the door. If this is put in as 2.5mm the actual door is recessed 5mm. We need it to be 1.25mm in the controll box to get the real value to be 2.5mm.
Images and a cabinet where this issue is happening attached.
